Suche CDXL (HAM-6) Player für 68000 CPUs -->Amiga 500/600
Striker
Beitrag von Striker »
Jo genau ich suche den Player aber absolut wichtig für 68000 CPU's!
Ein simpler Shell, CLI Player würde schon ausreichen.
Wichtig wäre, dass Bild und Ton (zumindest auf 11KHz Mono) wiedergegeben wird.
EDIT:
Oder anders herum gefragt:
Wisst ihr ein CD-TV Spiel das Videos als Intro oder Zwischensequenz zeigt?
Danke!!
Viele Grüße,
Reini
http://amigamap.com/
Striker
Okay, das hab ich ja schonmal was gefunden:
http://www.youtube.com/watch?v=O2k3fh_I5JQ
http://eab.abime.net/showthread.php?t=48784
Megainteressant... ich lese mich mal ein. :)
EDIT:
Yeah, gefunden. Vielen Dank an TJ Edmister von der New york amiga group auf Yahoo. :)
Aus der Readme:
AVI to HV converter 2011 DEC 12
damage_x@hyakushiki.net
http://www.hyakushiki.net/
contents:
HAMP.RUN - Amiga 68K executable for video playback, requires filename as
argument eg. HAMP.RUN WHATEVER.HV
AVI3HV.EXE - original converter program written in QuickBASIC for DOS
(slow, and may not work on recent versions of Windows)
AVI3HV.BAS - QB source
AVI4HV.EXE - updated converter compiled using freeBASIC for win32
AVI4HV.BAS - freeBASIC source
Instructions for using this program
First, create an AVI file with 15-bit RGB (555) uncompressed video,
and with the desired framerate. (Must be 320 pixels wide and max.
216 lines.) Save the audio as a separate uncompressed 8-bit WAV file.
(mono and stereo are both supported, sample rate must be less than 29KHz.)
Virtualdub is a good program for this purpose.
Run AVI4HV with the AVI file specified on the command line.
Example:
AVI4HV RAWVIDEO.AVI
The program will attempt to parse the AVI header and will
display some information like resolution, framerate, etc.
If this info is wrong then there is some kind of problem and
it probably isn't going to work. Otherwise, it will then ask
you for the path/filename of the audio file, the output file
name, and finally the option of dithering.
When the conversion is running some rubbish will be displayed
on the screen (DOS version) or output video (Windows version).
Playback may be limitted by the speed of the CPU and disk on
the Amiga. I have tested on an '030 accelerated A2000 and an A1200
with a 1.3GB IDE drive and full screen videos at 15fps were possible.
Ansonsten kannst du ja auch nochmal auf der CD32-Allianz-Seite von ehemals Thorty vorbeischauen.
Beitrag von Janusz »
Da gibts ne Amiga-Lösung auf den Allianz-Seiten... wenn die von Dir - Striker - genannte DOS Variante aber einigermaßen klappt, würde ich mir die Amiga-Version nicht antun. Ich hab´s seinerzeit mal verprobt, das macht keinen Spaß ... auch nicht am EMU ;)
Striker
Ja Leute HAM6 macht Spaß!!!! :bounce: :bounce:
Hab mir eben alle 3 japanischen Videos von damage_x am Amiga 500 Plus angeschaut. Das geht unglaublich gut. Oh mann in Verbindung mit einer AlfaData AlfaPower IDE 8MB Erweiterung samt CF IDE Adapter ergeben sich ganz neue Möglichkeiten. Filme in Spielfilmlänge und das mit Standard 68000 CPUs!! :)
Aber nicht mit 1fach oder 2fach CD-ROM (CDTV/CD32) ;)
Striker
Nö das nicht unbedingt bzw. mit Ruckler. Aber das nette Ding da in deiner Signatur wird mehr als ausreichen. ;)
Höh du hast ja sogar eine 68010er reingesteckt... :bier:
Du Speedfreak. :D
Nein, ich meine damit: Wenn Du mit nem CDTV oder CD32 rumhantierst, bestimmt die Geschwindigkeit des Laufwerks nachhaltig die Qualität des Films. Die CPU hat da eher wenig Last mit. Bei Festplatte/ CF ist das kein Thema.
Die 68010 ist für nur den Opcode, der für manche Quitkeys (WHDload) benötigt wird ;)
Bluebird
Beitrag von Bluebird »
Naja ich hab mir auch erst HV Movies am CDTV angeguckt und war schon verwundet wie Gut das aussieht und auch laeuft !
Wobei ich hab schon auch ne 68010 und 2 mb Fast im CDTV und ohne das 4x Externe CDLW wuerd da auch nichts laufen , aber damit geht das schon ganz Gut :)
Ich glaube der Clip hatte 320x200 HAM 6 mit 12 FPS ... klar ein Film braucht da Gut 1 GB und mehr , aber wenn man noch ne CF drin hat ist das kein Thema :)
wenn es da einen Konverter fuer denn PC geben wuerde dem man alle Avi und Mpeg Formate vorwerfen koennte , wuerd ich sicher davon ab und an gebrauch machen , aber wie bei fast allem ist das Coden zu Kompliziert :(
mfg Bluebird
Striker
Ist gar nicht mal so schwer. Ich kann dir mittlerweile so ziemlich jedes Video was du willst ins Ham6 Format konvertieren. Nur wie du schon richtig bemerkt hast, ist der Speicherbedarf durch das Fehlen von jeglicher Art von Komprimierung, enorm. :)
Habe 2 Videos zum selbst probieren in meinem anderen Thread hochgeladen (rapidshare). ;)
Bluebird
Hmm in welches Format muss man denn die Videos bringen das es der HV Konverter umwandeln kann ?
Seit Jahren hab ich da nichts mehr Konvertiert und fand Virtual Dub und Konsorten damals schon schlimm :)
Ein Paar Musik Clips zum angeben mit dem CDTV waeren aber schon mal ganz Nett *grins*
mfg Bluebird
Striker
Wichtig, schneide zu Beginn mal das Video auf max. 10 Min.
Dann speicherst du mit Virtual Dub Audio als Wave ab.
Du stellst Virtual Dub auf No Audio Processing
Jetzt mal zum Video
-320x216 (für schwache Amigas kannst du brutal auf 320x135 runtergehen dafür aber dann 15FPS)
-Nicht mehr als 25FPS (für 68000 CPUs ohne großartiger RAM Erweiterung 10 FPS!)
-Halte das Video unter 10 Minuten (wobei ich schon einen Weg weiss, wie man auch einen Kompletten Film in Spielfilmlänge für den Amiga 500 konvertieren kann. Dazu aber später mal mehr auf Youtube.... :D
-stelle bei VirtualDub auf 16bit RGB (555) Farbtiefe
Ich arbeite am Liebsten mit 320x216 mit 10FPS für meinen Amiga 500.
Für einen 68020er kannst du auch 20FPS machen.
Jetzt nochmals zum Audio:
Nimm Audacity und GoldWave zum detaillierten Schneiden.
In den meisten Fällen reicht aber Audacity.
Stelle dort auf 11kHz.
Gehe auf Export 8bit uncompressed wav
Du solltest nun ein 11KHz 8bit Stereo Wave haben.
Nun nur noch mit avi4hv in einer DOS Eingabeaufforderung zusammen mischen und fertig ist dein wasauchimmer.hv :)
Lass uns Teil haben an deinen Videos.
Ich habe ja schon ein paar hochgeladen. ;)
Bluebird
Nach stunden langem Versuchen muss ich zugeben das ich auf die Bebilderte Anleitung oder denn Youtube Makeing OF warte ...
Denke mal denn Virtual Dub Part selte ich hinbekommen haben :) aber dann bei Audacity setzt es aus , 11 khz war immer verzerrt , k.a vielleicht hab ich am falschen Schalter gestellt ... schon schade das die Soft zwar Amiga IFF anbietet letztenendes aber einen Fehler ausgibt wenn man so Speichern will !
Eigentlich schade das es kein gescheites Tool gibt das einem das bisschen Arbeit in einem abnimmt , also ein 11 khz 8bit Wave erstellen sollte doch eigentlich mit VIrtual Dub schon moeglich sein ... und dann kann Virtual Dub noch nichtmal FLV von Youtube direkt umwandeln ? selbst einige meiner SVCD Clips hat es nicht gefressen :(
also irgendwie steig ich da nicht so ganz Durch und avidemux was ich bisher am besten Fand nuzt mir bei dem Projekt leider garnichts :(
mfg Bluebird
