TuneNet OS4
Verfasst: 31.07.2005, 17:44
von Big H
Es ist vor kurzem ne neue Version von TuneNet erschienen und zwar die V0.60 Alpha
TuneNet ist nen OS4 nativer mp3 Player mit dem auch internet Radio streams abgespielt werden können.
Dafür das es ne Alpha version ist läuft das ding schon recht annehmbar rund.
http://www.tunenet.co.uk/download.html
Verfasst: 02.08.2005, 16:26
von Big H
und wieder ne neue version V0.60r2 Alpha
Verfasst: 24.12.2005, 14:08
von Big H
Verfasst: 03.01.2006, 00:59
von Big H
und weiter geht es mit V0.72a
http://www.os4depot.net/?function=showf ... unenet.lha
This a Music Player for AOS4 that can support Shoutcast / MP3 files and Plugins
(Currently PT, AIFF, AHX and Ogg Vorbis).
Changes from the V0.70a release
V0.72 - New Year Release
* MP3 detection improved (for use with the OGG Vorbis plugin!!! ).
* Double click on Plugin List added to get a description of the plugin.
* Docky D&D Send Message improved to fix problems with other dockies such as
YAM.
* Playlist detection from WB / CLI / D&D (.m3u extension recognised).
* m3u files with comments are now handled.
* m3u relative paths now supported (great for files produced by CD Rippers).
* Playlist loading now silently checks for the playlist files existence before
(checking &) adding them to the list.
* New OS4 style Requester boxes added.
* Help "bubbles" can be toggled on or off from the settings menu and at
startup from the preferences.
* Fixed a bug in the Find routine which could give some false positives.
* MP3 Icecast support added (wasn't too difficult)
* http streams within m3u files now allowed.
* Improvements to stream recovery and forced restarts on buffer empty.
* Single streams specified from the cli "-stream" option or from m3u files can
now be saved along with the playlist.
* DNS timeout added to finally halt any long term network related lockups
(6 second time out by default).
* Blank URLS in PLS files are now handled without crashing the task.
* Spaces in URL's are now converted to %20
Verfasst: 17.04.2006, 21:43
von Big H
Es gibt ne neue version 0.78a
Verfasst: 17.04.2006, 22:45
von RetroMan
Hmmm, 0.78a hat bei mir irgendwie Probleme die Internet Radio Stations scannen bzw. zu finden :?:
Abspielen selber geht ohne Probs :roll:
Verfasst: 18.04.2006, 09:23
von Big H
stimmt das macht auch hier probs.
nimm mal in den prefs die gui priorities hoch als ich die von 5 auf 8 geändert habe hatt er sofort die sender gefunden
Verfasst: 18.04.2006, 20:07
von RetroMan
K, werd ich nachher gleich mal testen ;)
Verfasst: 22.04.2006, 20:38
von Big H
weiter gehts mit V0.78r4a
Verfasst: 22.04.2006, 22:55
von RetroMan
Nu klappts auch wieder mit den Sendern :bounce:
Verfasst: 15.10.2007, 18:38
von Big H
Ne neue Version ist da und die ist verdammt legga es werden nun endlich skins unterstützt :D
