neues WLan-Prism2-Device released!
Verfasst: 09.08.2005, 07:12
Link: http://www.ann.lu/
DL from Aminet: http://main.aminet.net/hard/drivr/prism2.lhaPrism2.device, the SANA-II network driver for 11Mbps wireless Ethernet cards based on the Prism II chipset and variants, has new version available. It seems to be only an A600 related bug fix only.
" Changes in this version:
-Fixed an alignment bug that made it impossible to use WEP on an A600 (without a CPU upgrade). If you install the new driver version, it's important that you install the new SetPrism2Defaults command too, as the old command is incompatible with the new driver."
