WHDLoad 16.5 released !
Verfasst: 17.12.2005, 00:24
von HOL2001
Ja hallo erstmal,
ich weis nicht, ob sie es schon wussten... Aber...
WHDLoad 16.5 has released !
Just go get it!!!
http://www.whdload.de/
*** 16.5 (15.12.2005)
- new: check for CyberGraphX/56KHZAUDIO added (David Roeskamm)
- new: commands PL_ORB/W/L added for patch lists (Psygore)
- chg: if XPK decompression fails during preload WHDLoad shows the
missing sublib name too
- fix: kickemu correctly updates IO_ACTUAL on trackdisk accesses (JOTD)
- chg: russian translation reworked (Manbiker)
- new: display promotion added to kick31emu, with that WHDLoad options
DblPAL and DblNTSC become working in conjunction with installed
games using kick31 emulation and supporting it
- fix: stackcheck modified to avoid complaining if first long word of
stack is trashed (e.g. when using WarpOS-XPK-Sublib and running
from Workbench)
- chg: bubble help for bplcon* registers added to WHDLoadGCI
- fix: improved startup code for kickemu and _bootdos in kick13.asm
- fix: disassembler for negative absolut word addressing fixed (Psygore)
- chg: improved error messages on resload_Patch(Seg)
- new: slovak translation added, thanks to Jan Zahurancik and Martin Durik
- new: ukrain translation added, thanks to Andrey Molchanov
- chg: improvement on resload_ProtectSMC, instructions modifying the sr
no longer break the SMC check, autodocs fixed, disabling trace is
no longer required with SMC check (JOTD)
- chg: text explanation added to register dump for attnflags and setcpu
- chg: Snoop on 68060 now allows change of bit #6/7 of ciaa.ddra which
is used on accessing/detecting joypad
- new: if WHDLoad is started without an slave argument from the CLI it
shows a short help for all options and some raw key codes
- chg: improved speed on preload for resload_Examine, now uses dos.ExAll
and memory pools (when running on v39+)
- chg: kick31emu got a new option called JOYPADEMU, formerly included in
INIT_LOWLEVEL now separated to support GetLanguage without joypad
emulation, also the joypademu has been improved, now the keys
used are user configurable using the Custom option
- chg: options ExecuteStartup and ExecuteCleanup are now local and
global useable (Ralf Stützer)
- chg: file PreLoad improved, uses now dos.ExAll, memory pools (if
running under v39+ and more than 4MB free fast available),
asynchronous decrunching of XPK files
- new: supports also the kickstart images supplied with Cloantos Amiga
Forever CDs, kick130.rom or amiga-os-130.rom must be renamed to
kick34005.A500, kick310.rom or amiga-os-310.rom renamed to
kick40068.A4000, images together with the rom.key must be
installed under DEVS:Kickstarts, some older installs require a
kick40068.A1200 image these installs wont run with Cloantos roms
- new: norwegian translation added which is not complete but better than
none, thanks to Herman Andresen
DL: http://www.whdload.de/
Quelle: EAB ;) (habe auf den Link verzichtet)
Verfasst: 17.12.2005, 00:47
von RetroMan
Gute News :D
Ich würds aber eher unter Amiga SOFTWARE einordnen ;)
*moved* :bier:
Verfasst: 20.04.2006, 18:12
von gunatm
18.04.06 new: Window Wizard (reLINE) done by CFOU! (Info)
18.04.06 improved: Snow Bros (Ocean) imager fixed, stack relocated, smc removed, blitter waits added (Info)
18.04.06 new: Global Trek / Evil Dawn (ECP) done by CFOU! (Info)
18.04.06 updated: Eye of the Beholder (Westwood/SSI) complete rewrite, uses files instead images, docs added (Info)
18.04.06 improved: Eskadra (LK Avalon/SUN Production) supports another version (Info)
14.04.06 new: Snow Bros (Ocean) done by CFOU! (Info)
12.04.06 new: Castles 2: Siege and Conquest (Interplay) done by JOTD (Info)
11.04.06 updated: Great Giana Sisters (Timewarp/Rainbow Arts) new imager and icons, sound and compatibility fixed, support for 2nd joystick button (Info)
neue Installer verfügbar!
Verfasst: 20.04.2006, 20:36
von CrazyIcecap
Semmelt das ganze eigentlich immer noch ab, wenn man Sermouse benutzt und dann in nem WHDLoad-Game die serielle Maus bewegt?
Verfasst: 21.04.2006, 06:55
von gunatm
Würde dich das wirklich wundern? :roll:
Verfasst: 21.04.2006, 09:26
von CrazyIcecap
Öhm...weiss nicht. Sollte es?
Naja, vielleicht sollte ich mir doch mal ein oder zwei neue Amiga-Mäuse zulegen... :D
Installer??
Verfasst: 22.04.2006, 09:12
von Novitian
gunatm hat geschrieben:
Installer ?? Was haben die für eine Bewandnis?? :eek: :?: Lasst mich nicht dumm sterben :roll:
Novitian
Verfasst: 22.04.2006, 09:24
von gunatm
WHDLoad bietet die Möglichkeit Original-Spiele auf die Festplatte zu installieren. Für eine solche Installation brauchtst du das Install-Skript.
Installer??
Verfasst: 22.04.2006, 10:27
von Novitian
gunatm hat geschrieben:WHDLoad bietet die Möglichkeit Original-Spiele auf die Festplatte zu installieren. Für eine solche Installation brauchtst du das Install-Skript.
WHDLOAD --> startet eine Slave-Datei, so kenne ich das. Hier hat sich jemand die Mühe gemacht ansonsten NICHT auf HDD installierbare Spiele auf HDD lauffähig zu machen. Großartige Sache
:D
Nun kann man zB. Eye of the Beholder ganz normal auf HDD installieren :P .
Wozu nun das Scrip!!
Thanks for your answer!!
Verfasst: 22.04.2006, 10:41
von gunatm
Ohne diese Installs könntest du nicht von Originaldiskette installieren.
http://www.whdload.de/download.html
Installation
Der einfachste Weg WHDLoad und die zusätzlichen Programme zu installieren, ist das mitgelieferte Installationskript zu benutzen.
Wichtig ist, dass die Programme ohne Pfadangabe erreichbar sind. Deshalb ist der empfohlene Platz "C:". WHDLoad kann auch in demselben Verzeichnis wie die installierten Spiele und Demos abgelegt werden (in den Projekt Icons ist nur "WHDLoad" ohne jede Pfadangabe eingetragen).
Die Programme "DIC", "RawDIC" und "Patcher" sollten immer mit installiert werden, da sie von vielen Installs benötigt werden.
Du verbuxelst da etwas! ;)
Installscript ...
Verfasst: 22.04.2006, 13:12
von Novitian
@gunatm :)
vorgestern habe ich EOB1 und EOB2 von Originaldisk's auf die HDD meines 1200-er installiert. Läuft, passt, wackelt und hat Luft :D :lol:
Wozu ist nun das WHDLOAD-script, wenn die Originaldisketten eine Installtion doch gestatten :?: :?: :?:
Bei vormals nicht zu installierenden Spielen wäre mir solch Script ja logisch...
Gruss Novitian
Verfasst: 22.04.2006, 13:38
von RetroMan
Der Installer (das SCRIPT !!!) ist nichts anderes als eine Batch Datei, die mehrere CLI Befehle nacheinander abarbeitet ;)
Dass es auch Installer für Spiele gibt, die sich eh auf HD installieren lassen liegt meist daran, dass die orginal Routinen fehlerhaft sind und um das Spiel auf andere CPUs anzupassen auf denen der orginal Install sonst nicht laufen würde :)
Verfasst: 24.05.2006, 19:04
von shoshone
ich kuck jetzt nicht nach, aber ich könnte mir vorstellen dass das script unterderhand rawdic mit aufruft..?
