AmigaSYS 4 AGA update for Real A1200/4000
Dary
Anmeldedatum: 04.06.2005
BeitragVerfasst am: Di, 07.04.2009 10:05    Titel: AmigaSYS 4 AGA update for Real A1200/4000 Antworten mit Zitat
News&fixes:
- AmigaAMP FPU/noFPU version support integrated. 3.0/3.1/3.9
- Pointer selection, 3 different pointers to choose (right menu, prefs...), Default AmigaOS red, Hand and White. 3.0/3.1/3.9
- WinUAE mount files added (UAESCSI 0-5 for AmigaOS 3.9 installation under WinUAE). - 3.0/3.1/3.9.
- The base AmigaSYS Amiga IDE CD mount file, retested, corrected. - 3.0/3.1/3.9.
- Beta CD mount file for Amiga 4000, it should be stable with this (Amiga IDE A4000 TEST - 1.2). - 3.0/3.1/3.9.
- Checkbox and window display errors corrected after the installation of AmigaOS 3.9 BB2. - 3.9.
- 68020/68030 compatibility modes updated. - 3.0/3.1/3.9.
- Added support for Commodore Amiga 4040 CPU card. - 3.0/3.1/3.9.
- Complete French language support. - 3.0/3.1/3.9.
- Languange, spelling corrections, updates, etc. - 3.0/3.1/3.9.
- Broken AmigaSYS 4 BIOS menu repaired. - AmigaDOS
- All DBLPAL resolution errors were corrected. - 3.0/3.1/3.9.
- etc...
The package is compatible with all AmigaSYS 4 - AGA A1200/A4000 base packages.
The update works with AmigaSYS 4 systems with the following AmigaOS installations:
- Commodore AmigaOS 3.0/3.1, Amiga Forever 3.0/3.1, H&P AmigaOS 3.9, Amiga Forever 3.x, 3.9 BoingBall 1/2.
more infos, download, etc:
http://amigasys.extra.hu
AmigaSYS is a fully pre-configured AmigaOS system. Support AmigaOS 3.0/3.1/3.9. Platforms: Amiga computers and emulators. http://amigasys.extra.hu
huepper
Anmeldedatum: 05.11.2004
BeitragVerfasst am: Di, 07.04.2009 13:27    Titel: Antworten mit Zitat
Thanx Dary, great work. Wink
MINIAMIGA (4MB)
neoX
Anmeldedatum: 22.05.2008
BeitragVerfasst am: Di, 07.04.2009 16:03    Titel: Antworten mit Zitat
Really Good Work.
Thx!
I will install the update on my A1200. Smile
BeitragVerfasst am: Mi, 08.04.2009 08:05    Titel: Antworten mit Zitat
Thanx a lot! Smile
