-> http://strohmayer.org/sfs
1.13 (23.2.2008)
* Fixed OWB bug 178 (fonts related endless loops) in the AmigaOS4 fonts implementation.
* If loading a page failed the progress bar is set to 0 now.
* Added tooltype DISABLEGIFANIMS, if it's set the anims are still played once since usually the last image is better than the first.
* Added tooltype DISABLEJAVASCRIPT.
* Using shared libcurl, libssl, libxml2, libxslt and libz now, you have to download sobjs.lha, extract it and and copy them to SOBJS:. Not required if you use AmiUpdate to update OWB, the new shared objects are installed automatically.
* The shared libcurl uses DEVS:curl-ca-bundle.crt instead of S:curl-ca-bundle.crt (since it's not a script using S: was wrong).
* Mounting RANDOM: is not required any more.
