Link: http://www.notam02.no/radium/
DL: http://www.notam02.no/arkiv/src/radium061b_amiga.zip 1,2MBRadium ist laut Eigenwerbung "eine neue Art von Musik-Editor, die entfernt an einen Tracker erinnert jedoch ein neues Konzept verfolgt" (Screenshot).
Neu in Version 0.61b:
Setting fontsize and changing slider-widths previously did not clear some graphics, and caused a warning to appear. Fixed. Bug introduced sometime in V0.60.
The panic! fuction only worked properly when there was no reason to panic (ehem..). The stop-check is now put into the CIA interrupt hook provided by realtime.library instead, and should work okey. Press left+right mouse for 2-3 seconds, and the player will stop.
The black line below the global lpb and bpm variables sometime dissapeared. Fixed.
The quantitize value could sometimes overwrite the "L" in "LPB". Hopefully fixed.
Added the following functions for the Python/Etc API: getNoteNote, getNoteVolume, getNotePlace, getNoteEndPlace and getNumNotes. But the API needs a lot more work to be very usable though.
Fixed a potensial bug in the keyboard event receiver.
Added keybindings to put the various windows to front.
Added keybindings to maxmize and minimize the editor-window.
Made all windows register keyboard events so one dont have to select the editor window after selecting other windows.
Current loading/saving path is read from the file "Radium:loadpath.txt". Edit that file manually in a text-editor to set your own path.
Made max number of saved/loaded colors to be 256. Saving all colors in 16/24/32/etc. bit screens didnt work very well (at least not in WinUAE), and made huge config files.
Made the colomn showing exand info (the one to the right of line-number) dissapear if no line is expanded.
Made the clock show correct time regardless of relative block tempo.
