DL from Aminet: http://main.aminet.net/hard/drivr/prism2.lhaPrism2.device, the SANA-II network driver for 11Mbps wireless Ethernet cards based on the Prism II chipset and variants, has new version available. It seems to be only an A600 related bug fix only.
" Changes in this version:
-Fixed an alignment bug that made it impossible to use WEP on an A600 (without a CPU upgrade). If you install the new driver version, it's important that you install the new SetPrism2Defaults command too, as the old command is incompatible with the new driver."
neues WLan-Prism2-Device released!
Link: http://www.ann.lu/
