wookiechat für OS4 ,68k, AROS und MOS
Beitrag von Big H »
Unter http://www.os4depot.net/share/network/c ... iechat.lha könnt ih euch die version 1.9 von wookiechat für OS4 herunterladen.
Die neue version bietet unteranderem einen URL grabber damit ist es endlich möglich links direkt an den browser zu schicken ohne lästiges rauskopieren.
hier alle neuerungen auf einen blick
Changes 1.9
- /invite command implemented
- Incoming Channel Invite messages are displayed properly now
- Sounds can be played to alert you to a new tab opening, or a highlight word
appearing. It can be played always or just when the main window is inactive
- /list implemented, displays a sorted list of channels on the network in its
own tab. Doubleclicking will join a channel.
- All displayed URL's are now saved in the URL Grabber window, and can be
loaded
in a browser by double clicking on it.
- Channel Keyword support fixed up a little. It's now possible to change the
keyword without toggling +k off first.
- Choosing "Connect to Server" without first selecting an entry will no longer
reaper
- Bugfix: "topic set by" messages no longer create an extra blank line in the
logs
- Channel Keyword and Limit string gadgets are now updated when you join a
channel
Zuletzt geändert von Big H am 31.08.2007, 16:23, insgesamt 7-mal geändert.
Maverik
Beitrag von Maverik »
Tja leider nur noch für OS4, keine 68k mehr. :(
mfg
Andreas
Beitrag von Big H »
heute ist Version 1.9.1 von wookiechat erschienen und als besonderes schmankerl liegt auch wieder eine version für os3.x mit im archiev :bounce:
http://www.os4depot.net/?function=showf ... iechat.lha
Release Notes
Some users have reported random disconnection. Apparently turning off
event sounds fixes this. I dont see why that portion of my code would
cause such a problem though. Still, if you have that problem, turn off
sounds and see if that works.
WookieChat for OS3.x is back. I was sick of my friends getting taken
out by a bug in my dcc code. I got SAMBA to work, and my PC is operating
better in the summer (less humidity in the air I think), so I decided to
port my code back.
There is some documentation now to help explain WookieChat commands,
and hopefully make the program easier to understand for people new to IRC.
Maverik
hey sehr schön, gleich mal downloaden. :)
mfg
Andreas
Beitrag von Big H »
und wieder ein update aktuell ist nun version 1.9.2 (auch wieder os3.x unterstützung)
Some WookieChat features include..
- Multiple server support
- "Perform on connect" scripts
- Tabs for channels and private conversations
- CTCP PING, TIME, VERSION
- Incoming and Outgoing DCC SEND file transfers
- Colours for different events
- Logging and automatic reloading of logs
- mIRC colour code filters
- Configurable timestamps
- GUI for changing channel modes easily
- Configurable highlight keywords
- URL Grabber window
- Optional outgoing swear word filter
- Event sounds for tabs opening and highlighted words
P.S:
December 23rd 2005 - WookieChat 1.9.3 - Quick bugfix.. fixed crashes on the OS3 version when connecting to servers.. I hope. If people have problems with this release too I'm going on a shooting rampage.
http://wookiechat.amigarevolution.com/wookiechat/
Beitrag von Big H »
Gestern ist version 2.1 für OS4 und OS3.x erschienen.
New in this Release
I've fixed a serious bug thats existed for a long time without me
realising it. A work buffer wasnt the correct size, and memory was
getting trashed when a lot of traffic was coming in fast (like when
displaying a large MOTD while connecting to a server) but this has
now been fixed. Also, other misc crashes have been fixed here and
there, the number of users in the channel is now displayed in the
window titlebar, the ZiRC network's new usermodes are supported now,
and a few other tweaks have been made. (See the changelog.txt in the
archive for more details)
Beitrag von Big H »
Es gibt mitlerweile version 2.2 dieses genialen programms.
wesentliche neuerungen sind:
New in this Release
- Support added for clickable URL's
- CTCP SOUND support added. See the "Main Settings > Sounds" for the samples
directory. "/sound" to play!
- No more crashes if loading Wookie before a TCP/IP stack is running
- PING replys are now compatible with mIRC (removed an extra control character
from the end of a PING reply message that wasnt supposed to be there)
- Added a banlist window with unban button
- Added ban option to the nicklist popup menu
- The columns in the XChat/AmIRC-style display can have a fixed width now. See
the "power_users.txt" file for more information. Default is "auto resizing"
Das beste ist das man nu auch endlich über nen doppelklick auf ne url den browser öffnen kann und man nicht mehr den weg über den urlgrabber gehen muss :D
Und schon gibts WookieChat 2.3 Beta 1 ;)
-> http://wookiechat.amigarevolution.com/w ... un2006.lha
http://wookiechat.amigarevolution.com/w ... ct2006.lha 657kb WookieChat 2.4 Beta 4
Automatic reconnection when disconnected from a server. Configurable delay inbetween reconnection attempts, and maximum number of retrys
Added an ignore function and a nice GUI for it. This ignore function supports wildcards and can optionally ignore Text/CTCP/DCC
You can now choose to automatically connect to servers upon startup, and the server selection window can be hidden since it isnt required
Channel names displayed in the listview can be joined by double clicking on them
Wookie no longer removes leading spaces from outgoing text. This is quite useful when pasting programming source code in dev channels and you want to keep the indentation for readability
When transferring tiny files within 1 second, the entry in the dcc windows are no longer stuck on "transferring" and are now able to be removed from the list
Outgoing DCC RESUME seems to be working better
Previously, you couldnt copy text to the clipboard when text was being added to the channel display. I made it pause while selecting text, but internal functions were preventing text from being copied to the clipboard when you let go of the mouse button. I have now corrected this. So its now possible to copy text to the clipboard in a busy channel.
Zukünftige betas sollen hier http://wookiechat.amigarevolution.com/wookiechat/beta/ erscheinen.
My betas and changelogs will appear on this page from now on:
I've just uploaded beta 5.. The server password support was broken with the new changes in beta 4. I've attempted to fix it, but I really need people to test this for me because I dont know any password protected servers.
I'd appreciate it if people could test it in the following ways: 1. connect to server, 2. connect in new tab, and 3. see if it works with automatically connect on startup.
The password is masked out with * characters for better privacy, but the
password is not encrypted in the servers.txt file unfortunately.
Thanks guys!
Email results to james.carroll**xnet.co.nz
(replace ** with @)
WookieChat 2.4 ready.. the best wookie ever!
The installer script is back. It provides an easy way of upgrading while retaining settings. It even caters for MorphOS users by installing the OS3.x binary and MorphOS native MUI classes.
A few new languages are now supported. The complete list is:
deutsch, english, español, français, greek, italiano, norsk, polski, svenska
What does this program do?
It allows you to connect to Internet Relay Chat networks (IRC!) and chat
with other users in a text medium in real-time. Some of the server groups
are preconfigured to join an Amiga chat channel upon sucessful connection.
Changes 2.4
- Added a scrollbar to the Server List window
- Automatic reconnection when disconnected from a server. Configurable delay in between reconnection attempts, and maximum number of retrys
- Added an ignore function and a nice GUI for it. This ignore function supports wildcards and can optionally ignore Text/CTCP/DCC
- You can now choose to automatically connect to servers upon startup, and the server selection window can be hidden since it isnt required
- Channel names displayed in the listview can be joined by double clicking on them
- Wookie no longer removes leading spaces from outgoing text. This is quite useful when pasting programming source code in dev channels and you want to keep the indentation for readability
- Added an edit button for Command Aliases, and improved the Alias display
- The "Seconds idle" and "sign on time" information in a /whois request is displayed nicely now. The idle time is now displayed in days/hrs/mins/secs instead of just seconds. "59023 seconds" style idle times were annoying to work out!
- When opening tabs, WookieChat will check the size of the logfile, and if its over a certain limit, it will rename the logfile with the date appended to the end of the filename, and start logging in a fresh empty file. This feature can be configured and turned on/off.
- Added a three column display for Channel List's (obtained using /list), and channels are able to be joined by double clicking on their name. URL's in topics in the List are able to be double clicked too.
- Added a horizontal scrollbar to the Channel List tabs, so you can read long topics (accessed with /list)
- Added Clone detection. Can be switched on and off easily. This will detect if there are people who are logged in more than once from the same address
- /topic by itself will now display the current topic for the current channel, but "/topic text" will still change the topic if you have the correct privelleges.
- The /clear command is back! /flush will also do the same thing.
- Although there are configurable command aliases, I've added some built in aliases. "/j" to "/join", "/p" to "/part", and "/m" to "/msg"
- Fixed: The Window title wasnt specifying the right server name when on multiple servers and viewing the root server tabs
- Fixed: Previously, you couldnt copy text to the clipboard when text was being added to the channel display. I made it pause while selecting text, but internal functions were preventing text from being copied to the clipboard when you let go of the mouse button. I have now corrected this. So its now possible to copy text to the clipboard in a busy channel.
- Fixed: the server password functionality works
- Fixed: Tried to fix up the activity coloured squares. They were changing colour wrongly. When it goes green (to show that your nick has been typed) it shouldnt go red or blue sometime later, because thats a lower activity level.
- Fixed: When you have a private tab open to someone, the coloured activity square in the button no longer disappears when the person changes their nick
- Fixed: When transferring tiny files within 1 second, the entry in the dcc windows are no longer stuck on "transferring" and are now able to be removed from the list
- Fixed: Outgoing DCC RESUME seems to be working better
- Fixed: I commented out the pop pen notifys when I was attempting to make the Colour support less f*cked. I've readded them, so the colour buttons will actually change colour when you change them now.
- Fixed: Improved the pen handling slightly. The pens are ####ing up much less (or not at all) when you run Wookiechat on its own screen and use iconify
- Fixed: "Connect in new tab" doesnt crash anymore if you click without first choosing a server
- Fixed: Highlight can be triggered with Action messages now
- Fixed: Outgoing DCC CHAT not displaying incoming text from the other user
- Fixed: Multiple DCC CHAT requests from the same person werent being cleaned up properly and were causing 100% cpu usage when connections were closed
- Fixed: a buffer used for processing DCC CHAT was too small and was writing outside its space!
- Fixed: If someone changed a channel mode in channel 1, while you were currently viewing channel 2, wookie would attempt to make an identical change in channel 2. Note: It wouldnt do any harm if you didnt have ops in channel 2. The mode gadgets have always been fundamentally broken, but it should work good now.
- Fixed: Removed a Denial of Service bug. Highlight floods cant freeze you now. And the sample loading is more efficient and better for slow machines (it doesnt attempt to load the sound sample each time the highlight is triggered. Only on startup and when then settings are changed).
- Fixed: Lines in Connect scripts that didnt end with a newline had their last character removed. So "/join #amiga" became "/join #amig". Lines do not have to end with a newline anymore.
- Fixed: All unclosed logfiles for tabs are closed when WookieChat exits now
- Fixed: Memory got trashed when parting channels. I've redone about 5-6 lines of code that was written quite a long time ago when I was still learning C.
Link: http://wookiechat.amigarevolution.com/
IRC-Klient: Wookiechat 2.4.1 Beta 2
James Carroll stellt eine neue Beta-Version seines MUI-basierten IRC-Klienten Wookiechat für AmigaOS 3/4 zur Verfügung. Änderungen seit der letzten Veröffentlichung:
Attempt to fix up crashing when closing second networks
Parting channels on the Serenity IRC network no longer crashes. This network for some reason doesnt follow the IRC RFC exactly, and it was affecting Wookie badly.
Beta 2: The ignore function now ignores /notice messages
Beta 2: Testing new smaller tab sizes.
IRC-Klient: WookieChat 2.4.1 Beta 6
Beta 5: No more Server tabs anymore! its still a little buggy, but give it a try anyway
Beta 5: I'm now compiling with -03. That means optimise for speed. Previously I wasnt optimising on OS4, and only optimising on OS3 for filesize.
Beta 6: When messaging someone in private, away messages are only displayed once unless they change.
Beta 6: Dedicated server tabs can disabled/enabled. Configure this setting at: Main Settings > Servers. Server tabs can be closed now regardless.
Beta 6: When a person sends you a file with DCC SEND, the file comment field is filled with their nick and IP address, and the network name
Beta 6: Added a "Hide" menu item, with short cut, for quick iconifying.
Dl: http://wookiechat.amigarevolution.com/w ... an2007.lha 783kb
IRC-Klient: WookieChat 2.5
James Carroll stellt eine neue Version des MUI-basierten IRC-Klienten WookieChat für AmigaOS 3/4 zur Verfügung. Neu in v2.5 ist die Möglichkeit "join"-, "quit"- und "away"-Nachrichten zu unterdrücken, außerdem wird kein seperates "Server-Tab" mehr benötigt. Die Änderungen im Detail:
You can now close the leftmost server tabs
Dedicated server tabs can be disabled/enabled. Configure this setting at: Main Settings > Servers. Server tabs can be closed now regardless
Added an ENV variable for AmiUpdate compatibiilty
Bugfix: No more crashing when closing second networks
Bugfix: Parting channels on the Serenity IRC network no longer crashes
Added a workaround for a strange PREFIX parameter on the EnterTheGame IRC network
Bugfix: No more garbage characters bug when using cursor up/down to scroll through your input history. (used to happen at the end)
Type /playing or /tunenet to show whats playing in TuneNet. It's not that useful a feature really.. I added it by request. It's something nice to play with, just for ####s 'n giggles
You can optionally turn on smaller tab sizes, by running wookiechat with the "smalltabs" switch. i.e. "run wookiebeta_os3 smalltabs". I'm aware that they dont always look right though
Der Autor bedankt sich bei allen Anwendern, die WookieChat registriert haben für das "zusätzliche Taschengeld".
Quelle: Amiga News http://www.amiga-news.de/de/news/AN-200 ... 90-DE.html
