Link: http://www.amiga-news.de/de/news/AN-200 ... 83-DE.htmlWhat is the SView5 package actually ?
It does consist of a huge object-oriented module set
called "SView5-Library", that consists of many classes for
loading/saving (SV5Objects), processing (SV5Operators)
and rtg-displaying (SV5Drivers) graphics. These are
dynamically loaded and flushed, depending on the free
amount of memory - under the case, there are not many
similarities to OS 3.x datatypes.
There are several programs included:
- SView5: the powerful main program that allows to access all
options and settings, allows to load, save, process
and convert images - not only via the GUI but
also using ARexx and so on.
Includes a RTG-compliant screen-grabber!
- BatchProcess Batch conversion tool, for applying upto 4 image
processing operaters to a number of graphics by
wildcards and save them in a different file format,
e.g. load a bunch of JPEGs, then resize, dither
and save them as PNG files.
- PNG-Box5, dedicated tools for creation of graphics for
JPEG-Box5, WWW usage (HTML pages) with progressive/interlacing
GIF-Box5: and transparency support
- WinSlide: for viewing images in a window on public screens,
using as few memory as possible - smooth scrolling
inclusive! Supports 8 through 24 bit displays.
- ScrollSlide: like WinSlide but using its own screen,
for best colors even on 8 bit displays
- CyberSlide: like viewing images from SView5 using a CyberGfx
SV5Driver with 16/24 bit capability, but implemented
as small standalone program
- SuperSlide: like CyberSlide but for AGA screens and screen modes,
additionally dithering is done when necessary
- SVPrefs: for changing settings of SView5-Library modules
easily.
Most people forget about WinSlide and the other tools, even when
already been using the program for some time. So, don't forget
to check them out when testing :-)
There's also a huge difference between SView5 and the
SView Productivity Suite I + II CD-ROMs - as described on
their covers or at www.schatztruhe.de
SView5/-Library is NOT compatible with SViewIV and its predecessors,
it also is NOT compatible with previous versions of the library
and its sub-modules.
Keyfiles of predecessors won't work with any of the included tools.
OS 3.1 or greater is REQUIRED!
legale Key-Files und Zubehör gibt es natürlich auch!
Link: http://www.aminet.net/search.php?query=sview
