Ann.lu-Thread: http://www.ann.lu/detail.cgi?category=n ... 615172.msg
This library is a wrapper for use lot of PCI Bus on Amiga/Amithlon/Pegasos (GrexA1200/A4000 (require cybpci.library and latest Grex 68040/68060 library), Prometheus (require prometheus.library v2.x), Amithlon (require powerpci.library v2.x), Pegasos (require Pegasos+MorphOS)).
I'm happy to announce a major update on the OpenPCI RTL8139 device driver and new OpenPciInfo v1.5 release.
- New OpenPCI RTL8139 version 1.1b1 released :
Fix all possible halt transfert and problems during downloading/uploading.
- New OpenPciInfo v1.5 (added internal configuration information).
If you like this project, you can support it with Paypal Donate (link is on my Web Site).
Download these latest software on Official OpenPci Web Site : http://bvernoux.free.fr/DevPCI.php
Best Regards
Benjamin Vernoux
Fix all possible halt transfert and problems during download/upload.
- Added Watchdog on TX to avoid possible TX bug and reset & init RTL8139 chipset in case of TX bug (TX in progress without Transmit OK).
- Corrected a possible problem with ISR_LENCHG when cable is disconnected.
- Removed clear interrupt if current interrupt is not RTL8139 Interrupt.
- Fixed problems to use a new Mac Address in the chipset (nic_setstationaddress()).
- Fixed some possible problems on some architecture for nic_setstationaddress(), nic_update_multicasts() & nic_put_multi() i used host_to_pcicpy() to read IO memory instead of pci_inl().
- Fixed some possible problems on some architecture for nic_rx() for RxStatusHeader & PktLength i used pci_inw() instead of pci_to_hostcpy().
- Changed utility.library from v40 to v39 to be compatible with ROM3.0.
Best Regards
Benjamin Vernoux
