Wie baue ich das 3.1er Kickstart-Rom ein?
mein Kickstart 3.1 bekommen (A2000)
kan ich den so einbauen ?
Mfg Ralf
Mfg Ralf
Amiga anfänger
Nachfrage
kommst stark trauf an welche, Revision dein A2000-Board hat. Eventuell mußt du ein paar Anpassungen machen. Poste diese doch mal bitte.
MfG
MicGl
MfG
MicGl
Zuletzt geändert von MicGl am 11.06.2005, 14:30, insgesamt 1-mal geändert.
Meine Homecomputersammlung
3 x Amiga 500 * Amiga 600 * Amiga 1000 * Amiga 2000a * Amiga 2000
Amiga 1200 * Mod. Amiga 1200 * Amiga CD-TV * Amiga CD32
Installation guide for Amiga 2000
Although the installation of de ROM chip is not very difficult, it should be carried out very carefully.
If you have no prior experience with installations of computer components or if you have doubts about doing the installation yourself, please consult your retailer. Neither Amiga International, Inc. nor Vesalia Computer take any responsibility for damages resulting from attempted installation of the ROM chip.
Before you begin the installation, please switch off your Amiga 2000 as well as all peripherals and disconnect all cables from the computer. To avoid damages by static discharge, touch a grounded device such as a radiator.
Then follow these steps:
- Remove all five screws that secure the casing (two on each side, one on the back) and remove the housing lid by pulling it to the front.
- The floppy drive(s) and the power supply have to be removed with their attachment. Loosen the screws that secure the mounting support (up to seven, depending on the various models) and disconnect the cables (please note the alignment before!). Lift up the complete unit and put it aside.
2.04: 390979-01 (37.175)
Use a suitable tool (screwdriver) to remove the ROM from its socket. Please note the alignment of the chip (notch!) before.
Depending on the revision of the motherboard, there are different steps to take. The revision is printed on the frontmost left corner of the board. If it reads.
1989 Commodore, Amiga 2000, Made in Germany (BSW)
and the notch of the ROM socket is facing to the front, then you have to solder a connection from pin 1 to pin 31 of the ROM. This step is not necessary on any other board (print reads B2000-CR, notch facing to the back.)
Install the ROM chip into the socket. Please note that the orientation of the notches must match!
Warning:Installing the ROM with the notch facing in the wrong direction will destroy the chip!
The installation of the Kickstart ROM is complete. You can now reassemble your Amiga 2000
da ich kein englisch Bitte übersetzen oder wie man das machen kann.
MFG Ralf
MFG Ralf
Amiga anfänger
So baut man das 3.1 er Kickrom im A2000 ein :D
Lange Rede kurzer Sinn,
schraub das Ding auf und such das alte Kickrom (von vorne rechts neben der CPU).
Hebel dieses vorsichtig raus (z.B. mit nem Taschenmesser drunter gehen).
Dann den neuen Baustein vorsichtig einsetzen. (PIN 1 zu PIN 1 ; Kerbe gleich PIN 1)
Falls du ein Board hast, welches Made in Germany ist (steht drauf) mußt du noch eine Kabelverbindung von PIN 1 auf PIN 31 dir zurecht basteln.
Ansonsten müßte es so gehen.
Viel Erfolg
MFG
MicGl
Viel Erfolg
MFG
MicGl
Zuletzt geändert von MicGl am 11.06.2005, 14:29, insgesamt 1-mal geändert.
Besser so
So besser was meine Titel angeht Calo? (siehe vorherige Posts)
MfG
MicGl
MfG
MicGl
Bei der Revision müßte es reichen, einfach das alte Kickrom durch das neue zu ersetzen.
Du mußt nur darauf achten das neue Kickrom richtigrum einzusetzen. (PIN 1 auf PIN 1)
Mfg
MicGl
Mfg
MicGl
Der erste Blick geht immer auf die Power-LED ! Wenn die aus bleibt, ist was nicht in Ordnung, dann sofort wieder ausschalten !!
Hinweis: bei alten Amiga-Modellen (A500, A2000) geht die Power-LED komplett an und aus, bei neueren Modellen (A1200, A4000) wird sie heller und dunkler. Also wenn sie sofort angeht aber nicht heller wird, ist das genauso als wenn sie gar nicht an geht.
Nur, wenn der Amiga einen internen IDE-Bus hat (also im A600, A1200 oder A4000). Und auch da wird zuerst die Power-LED heller.warte mal nen bisschen kick 3.1 braucht länger beim starten.
