http://insertdisktwo.com/2015/12/24/whd ... -now-free/
Mfg Handyman
WHDLoad-Installs 2016 ...2016-06-24 new: Femme Fatale (Graphic Expressions) done by Psygore (Info)
2016-06-23 improved: Alien Breed 2 (Team 17) access fault fixed, level skip added, cheat mode added (Info)
2016-06-19 improved: Hollywood Poker Pro (Softgold) added quitkey for 68000 (Info)
2016-06-17 updated: Curse of Ra (Rainbow Arts) fixes crash at startup (Info)
2016-06-15 fixed: Shadow of the Beast 3 (Psygnosis) PAL version fully supported, freezes in intro fixed, Byte writes to volume register fixed, Bplcon0 color bit fixed, decruncher optimised and error check added, disk request screen disabled, intro can be skipped with CUSTOM2, disk accesses removed (Info)
2016-06-14 improved: Les Manley - Search For The King (Accolade) adapted for WHDLoad v17, fixed for 68000 (Info)
2016-06-14 updated: Faery Tale Adventure (Microillusions) reassembled with latest kickemu (Info)
2016-06-13 improved: Wrath of the Demon (Ready Soft) disk imaging fixed (Info)
2016-06-13 improved: Cruise For A Corpse / Croisière pour un cadavre (Delphine Software) sound fixed, division by zero fixed, supports italian version (Info)
2016-06-13 improved: Black Tiger (Capcom/U.S.Gold) fixed install script (Info)
2016-06-12 fixed: Humans / The Humans (Imagitec Design) keyboard works again (Info)
2016-06-11 fixed: Humans / The Humans (Imagitec Design) works on 68000 now (Info)
2016-06-09 new: Megademo 6 (Demo Disk 6) (Kefrens) done by StingRay (Info,Image)
2016-06-08 new: Megademo (North Star) done by StingRay (Info,Image)
2016-06-06 improved: Final Fight (Capcom) music during menu and fast character mirror supported, new install script (Info)
2016-06-01 improved: Cabaret Asteroids (Vertical) possible to start game with fire button (Info,Image)
2016-06-01 fixed: Rainbow Islands (Ocean) reverted to previous release (Info)
2016-06-01 new: Acid in the House (North Star & The Silents) done by StingRay (Info,Image)
2016-05-30 improved: North & South (Infogrames) adapted to new kickemu (Info)
2016-05-30 improved: Rainbow Islands (Ocean) new option to play without keyboard (Info)
2016-05-29 new: Megademo (Manowar) done by StingRay (Info,Image)
2016-05-28 new: Megademo (Cult) done by StingRay (Info,Image)
2016-05-26 new: Music Disk (Dreamscape) done by StingRay (Info,Image)
2016-05-25 fixed: Future Wars / Les Voyageurs Du Temps (Delphine Software) spanish version support (Info)
2016-05-25 new: Music Disk 2 (Darkness) done by StingRay (Info,Image)
2016-05-24 new: Harmagedon (Infect) done by StingRay (Info,Image)
2016-05-23 new: 2D (Remedy) done by StingRay (Info,Image)
2016-05-22 fixed: Red Heat (Ocean) crash on 68000 fixed (Info)
2016-05-22 new: Megademo 2 (Vortex 42) done by StingRay (Info,Image)
2016-05-22 improved: Future Wars / Les Voyageurs Du Temps (Delphine Software) supports spanish version (Info)
2016-05-20 new: Megademo (Mad Monks) done by StingRay (Info,Image)
2016-05-19 new: Megademo (Vortex 42) done by StingRay (Info,Image)
2016-05-18 new: Minor Defects (Grace) done by StingRay (Info,Image,Image)
2016-05-17 improved: Shadow of the Beast 3 (Psygnosis) added joypad controls, quit key on 68000 (Info)
2016-05-04 new: Megademo (Possessed) done by StingRay (Info,Image,Image)
2016-05-01 updated: Hybris (Discovery Software) reverted to previous install release (Info)
2016-04-30 updated: Z-Out (Advantec/Rainbow Arts) enabled VBL interrupt during game (Info)
2016-04-30 improved: Hybris (Discovery Software) smart bomb can be triggered using second joystick button (Info)
2016-04-30 improved: Badlands (Tengen) added second button, quitkey on 68000 machines, re-enabled VBL interrupt (Info)
2016-04-30 new: Sounddisk (Possessed) done by StingRay (Info,Image)
2016-04-17 improved: Global Gladiators (Virgin) added quitkey for 68000 machines (Info)
2016-04-17 improved: Cool Spot (Virgin) added quitkey for 68000 machines (Info)
2016-04-13 improved: Global Gladiators (Virgin) fixed lockup on checkered screen (Info)
2016-04-13 improved: Cool Spot (Virgin) chipmem usage lowered, fixed spurious interrupts (Info)
2016-03-28 improved: Quest For Glory / Hero's Quest (Sierra) updated install script (Info)
2016-03-28 improved: Marble Madness (Atari/Electronic Arts) buttonwait option added, splash window infos added (Info,Image)
2016-03-28 improved: Leisure Suit Larry 2 (Sierra) better install script (Info,Image)
2016-03-25 new: The Codertrash (Mexx) done by StingRay (Info,Image)
2016-03-23 new: Burning Spear (The Dark Demon) done by StingRay (Info,Image)
2016-03-20 new: Megademo (a.k.a. Hit Fido) (KGB) done by StingRay (Info,Image,Image)
2016-03-20 improved: Groovy Jives 3 (Relay) byte write to Bltcon1 fixed, keyboard interrupt problem fixed, decruncher optimised (Info,Image)
2016-03-20 improved: Alfred - The Music Disk (Relay) some more Bplcon0 color bit fixes, WHDLoad v17+ features used, keyboard interrupt problem fixed, decruncher optimised and error check added, install script updated (Info,Image)
2016-03-19 improved: Peace in the Gulf (Animators) Bplcon0 color bit fixes, some blitter waits added (Info,Image)
2016-03-19 improved: Music Party 1990 (Cryptoburners) Bplcon0 color bit fix, install script updated (Info)
2016-03-18 improved: Musicland 2 (Brainstorm) Bplcon0 color bit fix (Info,Image)
2016-03-18 improved: Musicland (Brainstorm) Bplcon0 color bit fixes, WHDLoad v17+ features used (Info,Image)
2016-03-17 updated: The Dogs Cogs (Nerve Axis) patch redone, uses real files, Bplcon0 color bit fixes, decruncher relocated, source included (Info,Image)
2016-03-16 improved: Crystal Symphonies 2 (Phenomena) illegal copperlist entries fixed, 68000 quitkey support, source included, new install script (Info,Image)
2016-03-16 improved: Crystal Symphonies (Phenomena, Scoopex, Rebels) Bplcon0 color bit fix, 68000 quitkey support, source included, new install script (Info,Image)
2016-03-16 improved: Hymn 633 (Damage) some more Bplcon0 color bit fixes (Info,Image)
2016-03-15 improved: The Long Dark Teatime Of The Soul (LSD) write to INTREQR fixed, WHDLoad v17+ features used (Info,Image)
2016-03-15 improved: The Triple Breasted Whore of Eroticon 6 (LSD) odd address copperlists disabled, WHDLoad v17+ features used (Info,Image)
2016-03-15 improved: Total Kaos (LSD) Bplcon0 color bit fix, WHDLoad v17+ features used (Info,Image)
2016-03-15 improved: Techno Warrior (LSD) Bplcon0 color bit fix, wrong CIA access fixed, WHDLoad v17+ features used (Info,Image)
2016-03-15 improved: Grapevine Megamix (LSD) some more odd address copperlists disabled (Info,Image)
2016-03-14 improved: Absolute Swedish (Phew! Productions) WHDLoad v17+ features (config) used (Info,Image)
2016-03-14 improved: Animotion (Phenomena) illegal out of bounds blit fixed, a few more blitter waits added (Info,Image)
2016-03-14 improved: Sound De Light (Software of Sweden) 2 more byte writes to volume register fixed (Info,Image)
2016-03-14 improved: Megademo (Software of Sweden) illegal copperlist entries fixed (Info,Image)
2016-03-13 improved: Megademo (Phenomena) byte write to VPOSW fixed, more blitter waits added, more Bplcon0 color bit fixes, out of bounds blit fixed, some wrong blitter wait patches corrected, illegal copperlist entries fixed, some more byte writes to volume register fixed (Info,Image)
2016-03-13 improved: Music Compacting 2 (Zylon & Alpha Flight) some more Bplcon0 color bit fixes (Info,Image)
2016-03-13 improved: Autumn Nights (Palace) copperlist termination fixed (Info,Image)
2016-03-13 improved: Amplifier II (Dimension 4) copperlist problem fixed (Info,Image)
2016-03-13 improved: Audio Violation (Defekt) copperlist problems fixed, missing source added (Info,Image)
2016-03-12 improved: Demon's Rage (Nerve Axis) illegal Bltcon0/1 values in line drawing routines fixed (Info,Image)
2016-03-08 improved: Boundless Void (Nemol) Bplcon0 color bit fixes, blitter wait added, illegal Bplcon2 value fixed, byte write to volume register fixed, read from VPOSW fixed, new install script (Info,Image)
2016-03-07 updated: Groovy (Lemon) patch redone, byte writes to Bltcon1 fixed, illegal BltCon0 values fixed, 68000 quitkey support, blitter waits added, works with 512k chip now, new install script (Info,Image)
2016-03-06 new: Public Attack (Cult) done by StingRay (Info,Image)
2016-03-06 new: Greatest Hits (Cult) done by StingRay (Info,Image)
2016-03-06 updated: Test Drive 2 - The Duel (Accolade) converted for newer WHDLoad (Info)
2016-03-06 improved: Prince of Persia (Jordan Mechner/Brøderbund) trainer improved (Info)
2016-03-06 new: Vectordance (Cult) done by StingRay (Info,Image)
2016-03-05 new: Kefmania (Cult) done by StingRay (Info,Image,Image)
2016-03-04 improved: Side Arms (Probe) patch is NTSC compatible now (Info)
2016-03-04 new: Vector Dance 2 (Cult) done by StingRay (Info,Image)
2016-03-01 updated: Ruff'n'Tumble (Renegade) fixed wrong keyboard interrupt (Info)
2016-02-29 improved: Archon (Electronic Arts) adapted to WHDLoad v16 (Info)
2016-02-29 improved: Archon 2: Adept (Electronic Arts) adapted for WHDLoad 16, reworked readme & install script (Info)
2016-02-29 new: Musical Secrets (Zite) done by StingRay (Info,Image)
2016-02-28 improved: Sound Disk (Zenith) unitialised copperlist problem fixed, wrong write to INTENA fixed, Bplcon0 color bit fixes added, WHDLoad v17+ features used (Info,Image)
2016-02-28 improved: Megademo (Zeus) illegal copperlist entry fixed, one more blitter wait and Bplcon0 fix added, intro part random generator recoded and included random data removed (Info,Image)
2016-02-25 improved: Final Fight (Capcom) now works on 68000, files can be crunched (Info)
2016-02-18 updated: Darkmere (Core Design) made 68000 compatible (Info)
2016-02-18 improved: Eye Of The Storm (Rebellion) supports the original disks (Info,Image)
2016-02-15 fixed: Brian the Lion (Psygnosis) works on 68000 now, quitkey, icons, manual added (Info)
2016-02-14 improved: Astro Marine Corps (Dinamic) 68000 quitkey support, all blitter wait patches removed, lots of trainer options added, support for 2nd fire button (grenades) added, interrupts fixed, MoveP instructions patched, WHDLoad v17+ features used (Info)
2016-02-09 updated: Turrican (Factor 5/Rainbow Arts) overall rework (Info)
2016-02-07 improved: Netherworld (Hewson) fixed for 68000, removed NTSC dependency (Info)
2016-02-07 improved: Bart vs. the World (Virgin) loading optimzed, more blitter waits (Info)
2016-02-07 improved: Ultimate Golf (Gremlin) 68000 quitkey support added (Info)
2016-02-05 updated: Airborne Ranger (Microprose) patch redone, movep instructions patched, blitter waits disabled on 68000, trainer options added, byte write to volume register fixed, new install script (Info)
2016-01-21 updated: Terminator 2 - Arcade Game (Virgin) patch redone, access faults fixed, blitter waits added, trainer options added, high-score load/save, new install script (Info)
2016-01-19 fixed: After Burner 2 (WeeBee Games/Sega) freezing bug at start of level fixed, invincibility trainer added, another icon added (Info)
2016-01-17 improved: Winzer (Starbyte) CDTV support added, long read from $dff006 fixed (Info)
2016-01-17 updated: After Burner 2 (WeeBee Games/Sega) patch redone, RawDIC imager, keyboard problems fixed, more trainers added, new install script, renamed to After Burner 2 (Info)
2016-01-15 updated: Wings of Death (Thalion/Eclipse) patch redone, uses real files, RawDIC imager, copperlist and bitplane problems fixed, lots of trainer options added, interrupts fixed, new install script (Info)
2016-01-13 new: Alfabet Smierci (Arte) done by Asman, Irek'72 (Info)
2016-01-13 improved: First Contact (Chris Newcombe) load/save support added, all checksum checks disabled, 68000 quitkey support, trainer added, interrupts fixed, new install script (Info)
2016-01-11 fixed: Chambers of Shaolin (Thalion) character saving bug fixed, Bplcon0 color bit fixes, blitter waits added, interrupts fixed, 68000 quitkey support, sound problems fixed, new install script (Info)
2016-01-08 improved: Revenge of the Mutant Camels 2 (Mastertronic) NTSC support added (Info)
2016-01-06 improved: Dyna Blaster (Hudson Soft) slave rewritten, CD32 joypad buttons supported, bugs fixed, new customs and icons added (Info)
2016-01-06 new: Black Hornet (Hi-Tec) done by StingRay (Info)
2016-01-04 new: Revenge of the Mutant Camels 2 (Mastertronic) done by StingRay (Info)
2016-01-03 improved: Total Recall (Ocean) support for budget version added, new install script (Info)
2016-01-02 fixed: Multi Megamix 2 (Kefrens) snoop bug removed, dma wait patched, new install script (Info,Image)
2016-01-02 improved: Goal! (Virgin) WHDLoad v17+ features used (config), a few blitter waits added (68010+ only) (Info)
2016-01-02 new: Manchester United: The Double (Krisalis) done by StingRay (Info)
2016-01-02 improved: Manchester United: Premier League Champions (Krisalis) writes to Beamcon0 and Bplcon4 disabled, Bplcon0 color bit fixes, WHDLoad v17+ features used, patch works with 0.5MB chip memory now (Info)
2016-01-02 improved: Defenders of the Earth (Enigma Variations) patch rewritten, trainer and CD32 joypad support added, blitter waits can be disabled with Custom2, decruncher relocated, ButtonWait support (Info)
2016-01-02 new: Sooty's Fun With Numbers (Alternative) done by Abaddon (Info)
2016-01-02 new: Mafdet And The Book Of The Dead Software Horizons (Kingsoft) done by Abaddon (Info)
2016-01-02 new: Space Assault (Software 2000) done by Abaddon (Info)
2016-01-02 new: Fighting Soccer (Activision) done by Abaddon (Info)
2016-01-02 improved: Netherworld (Hewson) RawDIC imager, supports another version, blitter wait patches can be disabled with Custom2, uses files, disk access removed, problem with second intro screen fixed (Info)
2016-01-02 improved: Satan (Dinamic) trainer added, blitter waits can be disabled with Custom2, trainer added, WHDLoad v18+ features used (Info)
2016-01-01 improved: Escape from the Planet of the Robot Monsters (Tengen/Teque) supports another version (Info)
2016-01-01 updated: Sinbad and the Throne of the Falcon (Master Designer Software/Cinemaware) patch redone, protection checks removed properly, final answer when talking to characters displayed for 5 seconds, manual added (Info)
