Was es da so neues gibt?
Schauts euch an auf der Website, habe ehrlich gesagt keine Ahnung, nutze es nämlich nicht - laden werde ich es trotzdem :-)
Homepage: klick me for webpage!
Download: klick me for download!
EDIT: Für Suchfaule gibts die News hier:
AmiKit Homepage hat geschrieben: - ADDED: Complete set of 32bit DualPNG icons by Ken Lester.
- ADDED: New set of startup pictures by Ken Lester.
- ADDED: New wallpaper images by Bal Xavier, Bojan Milovic and Alex McNeil.
- UPDATED: AmiKit - AmiKit.exe 1.4. Now with skin support.
- UPDATED: AmiKit - Locale AmiKit 1.1
- UPDATED: AmiKit - MorpheuZ 1.5. Now switches among Magellan II, Scalos and Workbench!
- UPDATED: AmiKit - RomFind 1.2. Now compatible with Vista GUI.
- UPDATED: AmiKit - ScreenMode AmiKit 1.5. New screen mode preset 1680x1050.
- UPDATED: AmiKit installer, now compatible with Vista.
- UPDATED: Startup-Sequence (a backup of the original one is made)
- UPDATED: WinUAE 1.4.4. Supports Vista and dual core CPU.
- ADDED: Deluxe Galaga 2.6c AGA Registered version by EMV Software http://www.emv-software.com/
- ADDED: Deluxe Pacman 1.7 AGA Registered version by EMV Software http://www.emv-software.com/
- ADDED: Leon (64k demo winner at Breakpoint 2007) by Elcrew (AmiKit:Demos/Leon/)
- ADDED: MidiPlay 2.65b by Janne Syväniemi. Plays MIDI files via Windows.
- ADDED: "Phantom" theme for AmiStart by Ken Lester (a backup of your AmiStart config is made)
- ADDED: Scalos 1.7 (41.5) beta - EXPERIMENTAL ONLY, will be enhanced in next AmiKit updates.
- ADDED: Scalos graphical theme by Ken Lester
- ADDED: Wet 5.1 by Chris Young (AmiKit:Internet/Wet/)
- UPDATED: AfA_OS 3.96+ (with experimental TitleShadow and Skin support)
- UPDATED: akFAXX-Datatype 45.70
- UPDATED: akGIF-Datatype 45.75
- UPDATED: akJFIF-Datatype 45.70
- UPDATED: akLJPG-Datatype 45.70
- UPDATED: akNAIL-Datatype 45.70
- UPDATED: akPNG-Datatype 45.75 (with ReqAttack fix enabled)
- UPDATED: akSVG-Datatype 45.70
- UPDATED: akTIFF-Datatype 45.65
- UPDATED: Amiga Image Strage System 4
- UPDATED: Codesets Library 6.4
- UPDATED: HivelyTracker 1.4
- UPDATED: JoinSplitter 1.31
- UPDATED: MakeCD 3.2d public beta 12
- UPDATED: MCC_BetterString 11.12
- UPDATED: MCC_NList 0.99
- UPDATED: MCC_TextEditor 15.22
- UPDATED: MCC_TheBar 21.4
- UPDATED: microgolded 8 SP 10
- UPDATED: mpegadt 20.5
- UPDATED: rtg.library 40.3994 (for WinUAE 1.4.3 and higher)
- UPDATED: SmartFilesystem 1.276
- UPDATED: VICE 1.22
- UPDATED: WinUAEHelp 2.1.0
- UPDATED: WHDLoad 16.8
- UPDATED: WookieChat 2.7 beta 12
- FIXED: Functionality of files in AmiKit:Utilities/win and AmiKit:Internet/win folders.
- FIXED: The screen mode incompatibilities between WinUAE 1.3.x and 1.4.x.
- REMOVED: Amster (OBSOLETE)
- REMOVED: GMPlay (used MidiPlay instead)
- REMOVED: strICQ (OBSOLETE)
