Verfasst am: Do, 17.03.2005 07:55 Titel: neue Version des Textviewers EvenMore |
Ab und zu kommt doch nochmal in die Verlegenheit sich einen grossen Text anschauen zu müssen/dürfen. Evenmore wird seit Jahren weiterentwickelt und wird auf einer recht lustigen Internetseite präsentiert.
| Zitat: |
Features:
Scroller window allows easier moving about documents.
AppWindow, AppIcon and AppMenu makes opening files easy. Not only can you drag files onto them, but also drawers, and a requester will appear!
Totally font sensitive.
Tooltypes and preference file(s) for configuring settings.
Can open the window on any public screen and move between them.
Can create it's own public screen to run on.
ARexx port for remote control.
Supports the numeric keypad and mouse movement.
Very clean and smooth scrolling.
String and pattern finding functions with search hilighting, including file and directory search.
Bookmarks for remembering positions in the document.
Quick load listview for opening documents fast.
Configurable GUI for quick access to features.
Supports plugin modules! (AmigaGuide, MSWord conversion, etc)
Can open multiple files. Up to 1000 files can be stored in memory.
Help available by pressing the help key.
Gadget help bubbles.
User-configurable filetypes, for passing certain files to different programs.
Support for ANSI Escape code sequences!
Uses EasyGUI, the best GUI in the history of the world.
Can use Asl or ReqTools library for filerequesters.
Option to save the file.
Send the file to an editor.
Print the file.
Configurable information bar.
Execute commands or open a shell on the window.
XPK compression supported.
File history menu.
Locale support.
Clipboard support. |
Maintainer-Homepage: http://www.evenmore.co.uk
DL: http://www.evenmore.co.uk/downloads/EvenMore.lha 540kb
Na gut ... er ist ein wenig religiös angehaucht! Nicht wundern!  _________________ ------------------------------
Verfasst am: Mo, 21.03.2005 08:08 Titel: |
Update: http://www.amiga-news.de/de/news/AN-2005-03-00080-DE.html
| Zitat: | EvenMore: Textbetrachter jetzt mit Datatype-Unterstützung
Für den Textbetrachter EvenMore liegt nun auch ein Datatype-Plugin vor. Dieses erlaubt die Anzeige jedes von Datatypes unterstützten Dokumentes (etwa mittels DocDatatypes).
Bitte beachten Sie, dass die übrigen EvenMore-Plugins Vorrang vor den Datatypes haben - sollten Sie also ein Dokument lieber per Datatype als über den entsprechenden Plugin anzeigen wollen, müssen Sie den Plugin löschen und den Speicher leeren.
Weiterhin wurde ein größeres Problem mit der Sprachenunterstützung behoben, durch welches zuvor einige Katalog-Texte an der falschen Stelle erschienen. Vergewissern Sie sich daher, das Hauptprogramm und den EasyGUI-Prefs-Plugin neu herunterzuladen, um dies zu beheben. |
Verfasst am: So, 18.02.2007 10:26 Titel: |
Link: http://www.evenmore.co.uk/download.htm
| Zitat: | Changed memory allocation commands to AmigaE specific ones, to see if this will fix the crashing people are experiencing. Let me know if this works
Also fixed a bug in the ASL and RT requesters, in which no file pattern was specified if not saved in the preferences
Fixed problem with preferences plugin again!
Fixed two very silly bugs. One in the Datatypes.plugin, which caused EvenMore to read past the end of a file
Another bug caused EvenMore to crash when changing the screenmode in the prefs plugin. Both plugins updated
Updated manual for Quickload executables |
Verfasst am: So, 21.09.2008 15:19 Titel: |
Link: http://www.evenmore.co.uk/ 0.65 Cool ... jetzt laufen die Versionsnummern rückwärts. Naja ... es gibt eine neue Version. _________________ ------------------------------
huepper
Verfasst am: So, 11.01.2009 20:30 Titel: |
http://www.evenmore.co.uk v.066
Mitten im Artikel schreiben ne neue Version ...  _________________ MINIAMIGA (4MB) |
Verfasst am: Do, 05.11.2009 07:54 Titel: |
Link: http://www.evenmore.co.uk/ 0.67 und hören nicht auf _________________ ------------------------------
shoshone
Anmeldedatum: 15.06.2005 Beiträge: 148
Verfasst am: Fr, 06.11.2009 00:38 Titel: |
ist ja ein ganz nettes progrämmchen, aber der mensch kennt wohl das legendäre muchmore von f. siebert nicht?!
von wegen "gibt nix gescheites", wie er auf seiner seite schreibt. stimmt überhaupt nicht. (PR halt ) |
Verfasst am: So, 15.11.2009 12:20 Titel: |
link: http://www.evenmore.co.uk/ Es gibt wieder eine neue Version.
@Shoshone Du kannst ja beide Programme mal bebildert gegenüberstellen und vorstellen.  _________________ ------------------------------
Verfasst am: Sa, 05.12.2009 14:34 Titel: |
Link: http://www.evenmore.co.uk/ Schon wieder? Respekt. Die aktuelle Version ist 0.67, und ich will nochmal in Erinnerung rufen, was die Software alles kann:
| Zitat: | Here are its main features
o Plugin system for viewing many different file types, such as AmigaGuide,
HTML, WordWorth, MSWord, RTF, directories, etc.
o User-definable filetypes plugin that can pass files based on extension to
external programs
o Supports ANSI escape code sequences for text formatting, including full
colour text for certain file types
o Links are clickable in HTML, AmigaGuide, directories and other file types
o Completely font-sensitive user interface
o Drag and drop files on the window to open them
o ARexx port for remote control
o String and pattern search functions, including file and directory search
o Configurable menus for frequently used documents, and history menu for
moving between opened files
o XPK loading and saving supported, with PowerPacker supported through
plugins
o Customisable graphic user interface
o Clipboard support
o Locale support
and more... |
Verfasst am: Di, 22.12.2009 13:05 Titel: |
0.69 ist draußen.  _________________ ------------------------------
Verfasst am: Sa, 11.02.2012 11:09 Titel: |
Link: http://www.evenmore.co.uk/ 0.75
| Zitat: | o Plugin system for viewing many different file types, such as AmigaGuide,
HTML, WordWorth, MSWord, RTF, directories, etc. |
Toll! _________________ ------------------------------
