ChocolateCastle is an application making task of creating custom BOOPSI and MUI classes easier. Programmers using these systems often avoid writing custom classes, being discouraged by a lot of boring and schematical typing. This is bad, because subclassing is the essence of the object oriented programmimg. It allows to get the best from MUI and BOOPSI. That is why ChocolateCastle has been created. A significant part of a typical custom class may be generated automatically. This is usually 2 to 5 kB of source code. Automating this work speeds programmimg up and helps avoiding simple typing errors.
Momentan gibt es nur eine Version für MorphOS, aber die 68k-Version ist in der Mache.
