DL: http://amiga.sourceforge.net/phps/logge ... 0.26.3.lha (8376kb)WMFTools is a set of utilities for convert vector images in Microsøft's native Windøws Metafile Format to more standard/open file formats such as EPS/PS, FIG, PNG or JPEG
DL: http://amiga.sourceforge.net/phps/logge ... -0.6.3.lha (6181kb)Netpbm is a toolkit for manipulation of graphic images, including conversion of images between a variety of different formats. There are over 270 separate tools in the package including converters for about 100 graphics formats. Examples of the sort of image manipulation we're talking about are: Shrinking an image by 10%; Cutting the top half off of an image; Making a mirror image; Creating a sequence of images that fade from one image to another; For more information on what the package does, see http://netpbm.sourceforge.net/doc.
DL: http://amiga.sourceforge.net/phps/logge ... .3-060.lha (6119kb)
Weiterhin findet man auf der http://amiga.sourceforge.net/ -Seite eine neue Version der XML2.lib (http://amiga.sourceforge.net/phps/logge ... ry-3.0.lha) und eine aktualisierte Version der OggVorbis Tools (http://amiga.sourceforge.net/phps/logge ... 01_68k.lha). Gerade die Leistungsfähigkeit des NetPBM-Paketes wird vielen älteren Amiganern bekannt sein. Ach ja ... die Grafikverarbeitung von ImageKick (http://amiga.sourceforge.net/?showpackage=ImageMagick) ist sicherlich auch noch einen Blick wert.F Tools is a collection of SWF manipulation and generation utilities, Included are:
PDF2SWF A PDF to SWF Converter. Generates one frame per page. Enables you to have fully formatted text, including tables, formulas etc. inside your Flash Movie.
SWFCombine A tool for inserting SWFs into Wrapper SWFs. (Templates) E.g. for including the pdf2swf SWFs in some sort of Browsing-SWF.
SWFStrings Scans SWFs for text data.
SWFDump Prints out various informations about SWFs.
JPEG2SWF Takes one or more JPEG pictures and generates a SWF slideshow.
PNG2SWF Like JPEG2SWF, only for PNGs.
WAV2SWF Converts WAV audio files to SWFs with MP3 Streams, using the L.A.M.E. MP3 encoder.
AVI2SWF Converts AVI animation files to SWF. It supports Flash MX H.263 compression. Font2SWF Converts font files (TTF, Type1) to SWF.
SWFBBox Allows to readjust SWF bounding boxes.
SWFC A tool for creating SWF files from simple script files.
SWFExtract Allows to extract Movieclips, Sounds, Images etc. from SWF files.
Quelle: http://amiga.sourceforge.net
